The checkpointing message for I-SID cannot be processed in the active or the standby MM. This will result in the I-SID database on the standby MM not being in sync with that on the active MM. This condition will not impact PBB operation until after a failover of the currently active MM.
Check if check-pointing is enabled. Also, undo and redo the configuration when both MMs are in sync.
Debug-Summary
Failed to %action% for PSI of %psiName% with error %ret%
| Name | Type |
| action | String |
| psiName | String |
| ret | sInt |
